I am a novice related to scripts. I hope this info makes it clear what I am asking.
There is a website I use, that is now blocking use unless I disable my ad blocker (Shields).
I am unsure if you can see this site internationally...it is a TV Listing Guide.
www.titantv.com
I can bypass the prompt (initially it lets you continue, but after a few times, it won't let you use the site) by enabling "block scripts". (see pic)
if I disable scripts, it will not display the prompt, but I then can't use any features, like select only movies, or favorites, scroll forward or back in time or date, etc...nothing works. All of that works off of scripts, I assume.
Is there a way to isolate the script causing the prompt only, but all else can work properly?
Can We Isolate and Block Individual Scripts?
- The prompt disables usage
- script.GIF (36.94 KiB) 查看 242 次
- The blocked scripts
- scripts.jpg (75.85 KiB) 查看 242 次
Re: Can We Isolate and Block Individual Scripts?
Solve the problems caused by the advertising rules by yourself! Officials do not intervene in the relevant advertising rules to avoid unnecessary trouble.
That's why I posted under "expert help" and not under "bug", etc....
I thought some forum users with that knowledge could help me figure it out, not necessarily you officials....no worries, just asking...
This is actually not difficult, as long as the JS needs to be intercepted.
just reporting back, if any users care...
FYI - fixed my concern of scripts by using an extension named uMatrix and figuring out which controlled the prompt and which allows me to navigate the guide.
