It seems it's only problematic on Catsxp. I closed my issue on Brave's repo since I can't run Brave to test as these people suggested because I'm using Windows 8.1. It's a shame for me to reach out to them for help since I'm not even using their browser. What I'm using is just a rebranded fork of Brave!
https://github.com/brave/adblock-rust/issues/282
Any users have the same problem with appnee.com or just I'm bad luck?
appnee.com
Re: appnee.com
It's fine on UbO. This only happens with Catsxp Shields even though I tried to use the same filter lists as UbO.
Re: appnee.com
It should be that js detected that the advertising filtering function was used, and the relevant js was found and filtered out together.
Re: appnee.com
From what the Brave guys said, I think the problem is only on Catsxp:
