Issue with tab icons
roger_m
帖子 roger_m »
Since a recent update, when I have many tabs open, tabs icons are only partially displayed. In previous versions the icon would be resized to fit the size of the tab, but now only about only a third of the icon is shown and rest is cut off.
Re: Issue with tab icons
Attempting to operate in Chrome
If the same problem exists, it is the new kernel and mechanism
roger_m
帖子 roger_m »
So does that mean it can't be changed? Or would it possible to change the behaviour?
roger_m
帖子 roger_m »
I am not having the same issue with other Chromium browsers. I just opened tends of tabs in the current versions of Edge Chromium and Coc Coc and in both cases the icons were displayed correctly.
3.11.5 beta-4 fixed!
roger_m
帖子 roger_m »
Thanks
