建议增加个功能,增加个“建议密码”的功能
danswer
帖子 danswer »
在网站或论坛需要注册时,需要设置密码时,自动生成字母+数字+符号且不规则的建议密码
Re: 建议增加个功能,增加个“建议密码”的功能
印象中这个是内核的默认功能
Which browser is in the screenshot? I don't understand Chinese nor I'm familiar with Chinese browsers other than Catsxp. The only browser I know that has this feature is Firefox and thus Firefox-based browsers also have this feature (if they don't modify the source code or preferences to disable it).
catsxp 写了: 2023年 9月 18日 23:34 印象中这个是内核的默认功能
I don't think so. Just tested on both incognito and normal window. Didn't see anything. Or is it disabled by default and need to turn on something on Settings?
Btw, I personally don't think this feature is something desirable or useful. On Firefox, I always disable it. More annoying than it worth. Sometimes instead of filling in passwords that already saved to let me login, it mistakenly think I'm registering and suggest a new password. If you carelessly click on it then your saved password for that site is replaced with the newly generated password (and of course this is an invalid password and so lost access to this account if you didn't backup the passwords somewhere else). Sometimes when I'm inputting in forms it also mistakenly think this is the password field and it suggested a new password for me even though I'm not registering a new account.
有这个功能吧!
不是特别直观倒是真的!
2023-09-19 074056.png (29.92 KiB) 查看 199 次
catsxp 写了: 2023年 9月 19日 07:42 有这个功能吧!
不是特别直观倒是真的!
How to enable and use this feature? I want to give it a try to see how it's implemented on Catsxp.
